Hi, is it possible to create new categories for schematic and panel layout components in Icon Menu (AutoCAD 2014) so that component types not listed in the categories provided can be organised? Can nice looking icons like the ones in Icon Menu itself be created or added?
Thanks, I'd appreciate any assistance.
Solved by rhesusminus. Go to Solution.
Hi, I couldn't get your request clearly. Can you able to post me a screenshot explaining your needs. There is something called user defined list in Electrical that might be useful to look at,
Yes.
In the icon menu wizard, just add a submenu:
Specify the properties:
The image file is a PNG-file, 40 bu 40 pixels. If image is bigger it will be scaled down.
The images should be located in C:\Users\[USERNAME]\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.2\enu\Support\Images, unless you have told AcadE to keep them somewhere elsa by manipulating the WD.ENV file.
Hi, thanks for that advice. That worked perfectly in creating the folder. I'll work on making the screen icons nicer as a png. I appreciate your assistance.
Cheers
