Hello, I have an issue when I am working with ACADE 2013, when I try to use Title Block Update, ACADE freeze itself, but when I press ESC key ends the command, I attach a image related about what I am doing, I did the ACADE 2013 tutorial, and then when I do step 6, it freezes.
Solved by RobinShou-Autodesk. Go to Solution.
From the sounds of it, you have somehow got the dialog box opening up off screen.
I can't recall how to rectify that offhand, but you could try increasing your screen resolution temporarily and moving the dialog to a area over the acad window before resizing to what you had.
You could also try hooking up a second monitor (I actually recommend this as standard). This gives you a second screen where you can have your toolbars sit and give you more screen area for your dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
Would you please check this post? there is a workaround in the post for this dual monitor issue for ACE2013 now. We are considering a fix for this issue now.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
