AutoCAD Electrical Forum
AutoCAD 2013 Issue with Title Block Update
4 REPLIES 4
JavZaMa
1284 Views, 4 Replies
Hello, I have an issue when I am working with ACADE 2013, when I try to use Title Block Update, ACADE freeze itself, but when I press ESC key ends the command, I attach a image related about what I am doing, I did the ACADE 2013 tutorial, and then when I do step 6, it freezes.
4 REPLIES 4
Icemanau
in reply to: JavZaMa
From the sounds of it, you have somehow got the dialog box opening up off screen.
I can't recall how to rectify that offhand, but you could try increasing your screen resolution temporarily and moving the dialog to a area over the acad window before resizing to what you had.
You could also try hooking up a second monitor (I actually recommend this as standard). This gives you a second screen where you can have your toolbars sit and give you more screen area for your dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
JavZaMa
in reply to: Icemanau
Hi, I was working with a second monitor, what I do not know if even this way that dialog box is off screen
Would you please check this post? there is a workaround in the post for this dual monitor issue for ACE2013 now. We are considering a fix for this issue now.
http://forums.autodesk.com/t5/AutoCAD-Electrical/Suddenly-cannot-peform-batch-plot-or-title-block-up...
Robin Shou
Quality Assurance
AutoCAD Electrical
Oh thank you so much, it fixed the issue, yei !
”Boost
