AutoCAD Electrical Forum
AutoCAD 2012 Electrical Home Use License
5 REPLIES 5
JOESTUMPF6082
1623 Views, 5 Replies
Do I still have the option to use a copy of AutoCAD on my home computer with the 2012 Electrical version?  We own two stand-alone licenses.  If so, how do I go about the registration of the home copy?
Joe
5 REPLIES 5
paulfhme
in reply to: JOESTUMPF6082
If you are on a subscription, then you are automatically approved for home use.  It's a perk.
JOESTUMPF6082
in reply to: paulfhme
Thanks for the quick response!
Where can I find this information in writing?
WJH1970
The information regarding home use is actually in the license agreement documentation.  If you don't know where this is, begin an installation...you have to click "accept" on the license agreement to continue, but this time, copy paste it out to a document and then search it for the text.
You would use your standalone license number for the home installation as well, and register it as you did the copy at work.  Autodesk does track this, so if you loaded it on 3 machines, you'd likely get a call. It's kind of a monitored honor system.
For network licenses, if I recall correctly, you would load the software as a standalone version with the same serial number and license key.  Just like the standalone copy, Autodesk monitors the standalone installs.  So if you had 10 seats attached to 1 license, you would have 10 standalone installs available for home use.
Can any moderators out there confirm this?
Tags (1)
MinKeng
Hi Joe,
It should be referred to privacy policy and contract of the product, and yes, we still allow customers to activate second “Home” machine (no registration will be required) since first “Work” machine already registered the serial number.
Min Keng
”Boost
