Is there a way to turn off the AUTO STACKING feature in the MTEXT editor.
Our company uses a lot of CT's and having to stop and select the stacked ration and unstack it is annoying.
As we rarely use fractions in any of our dwgs, it is a wasted function to us.
Using ACADE 2008 on WinXP...
Regards Brad
Brad Coleman, Electrical Draftsman
Solved by testsubject. Go to Solution.
Is using the "/" common for showing ratios? In the states we use ":" (i.e., 3000:5)
Brad,
This link shows how to permanently turn it off.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12545491&linkID=9240617
using the "/" is standard practice for showing ratios here in Australia. i believe it is the same in the UK.
Thanks for the solution.
Regards Brad
