AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
joshko
188 Views, 2 Replies
audit
I just started to run an audit report when I noticed that the audit was actually changing things on drawings...is there a way to undo this?
2 REPLIES 2
in reply to: joshko
"joshko" wrote in message news:1921435.1081275753030.JavaMail.jive@jiveforum2.autodesk.com... > I just started to run an audit report when I noticed that the audit was actually changing things on drawings...is there a way to undo this? > Thanks
in reply to: joshko
The AcadE AUDIT command is currently designed such that it attempts to "fix" problems it encounters related to bogus or otherwise invalid wire number inserts. Actions it may take include 1) trying to move an existing wire number back to the wire that it is associated with (ex: AutoCAD MOVE command used to reposition a wire number insert) and 2) deleting wire numbers that have totally "lost" their association with their wire network (ex: AutoCAD COPY command to manually place additional wire numbers). If you run this project-wide then there is no "undo". What changes are you seeing? Are they other than wire-number related? "joshko" wrote in message news:1921435.1081275753030.JavaMail.jive@jiveforum2.autodesk.com... > I just started to run an audit report when I noticed that the audit was actually changing things on drawings...is there a way to undo this? > Thanks
”Boost
