AutoCAD Electrical General Discussion
Valued Contributor
galashkina
Message 1 of 5 (349 Views)
Attribute XnPINn
349 Views, 4 Replies
10-10-2012 02:26 AM
Terminal block with the number HT0002 contains attributes X2PIN01, X4PIN01, X1PIN01, X8PIN01. The note did not find any information about these attributes. What are they used?
testsubject
Message 2 of 5 (339 Views)
Re: Attribute XnPINn
10-10-2012 07:40 AM in reply to: galashkina
In IEC, you not only assign a Terminal number to each Terminal (including each level in a 2/3 level terminal block) but you also can assign a nunber to each side of the terminal. Thiat information is be stored in the X#PIN## attribute.
For example, say we assign the top screw of a terminal (we will call this TB10)  to 1 (X2PIN01=1) and the bottom to 2 (X8PIN01=2).
Then, when running a To/From report, it would report a wire connected to the top of the terminal block to TB10.1 and to the bottom TB10.2.
This allows the designer to be very specific as to where a wire is landed on the terminal. (Since you can draw the schematic so that it depicts exactly how the system is wired.)
Also, the X# value represents its position on the block
X1 is Right.
X2 is Top
X4 is Left
X8 is Bottom.
Bob Hanrahan
Ace User since 1998
Valued Contributor
galashkina
Message 3 of 5 (308 Views)
10-11-2012 02:22 AM in reply to: testsubject
For example, terminal XT1 1 has two levels: top and bottom (pic1), pin numbers 1, 2, 3, 4.
These pin numbers are not the values of the attributes of the block terminals NT0002 (pic2).
Can I display the pin numbers in the drawing and report?
testsubject
Message 4 of 5 (300 Views)
10-11-2012 03:59 AM in reply to: galashkina
Can you post the image of pic2. I do not see it.
Bob Hanrahan
Ace User since 1998
Valued Contributor
galashkina
Message 5 of 5 (296 Views)
10-11-2012 04:41 AM in reply to: galashkina
I've had problems with attachment figures.
I have two signs made one
pic1=pic1+pic2
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
