AutoCAD Electrical General Discussion
Distinguished Contributor
20 Kudos
Post 1 of 5
Attribute XnPINn
370 Views, 4 Replies
10-10-2012 02:26 AM
Terminal block with the number HT0002 contains attributes X2PIN01, X4PIN01, X1PIN01, X8PIN01. The note did not find any information about these attributes. What are they used?
I've had problems with attachment figures.
I have two signs made one
pic1=pic1+pic2
76 Kudos
Post 2 of 5
Re: Attribute XnPINn
10-10-2012 07:40 AM in reply to: galashkina
In IEC, you not only assign a Terminal number to each Terminal (including each level in a 2/3 level terminal block) but you also can assign a nunber to each side of the terminal. Thiat information is be stored in the X#PIN## attribute.
For example, say we assign the top screw of a terminal (we will call this TB10)  to 1 (X2PIN01=1) and the bottom to 2 (X8PIN01=2).
Then, when running a To/From report, it would report a wire connected to the top of the terminal block to TB10.1 and to the bottom TB10.2.
This allows the designer to be very specific as to where a wire is landed on the terminal. (Since you can draw the schematic so that it depicts exactly how the system is wired.)
Also, the X# value represents its position on the block
X1 is Right.
X2 is Top
X4 is Left
X8 is Bottom.
Bob Hanrahan
Ace User since 1998
20 Kudos
Post 3 of 5
10-11-2012 02:22 AM in reply to: testsubject
For example, terminal XT1 1 has two levels: top and bottom (pic1), pin numbers 1, 2, 3, 4.
These pin numbers are not the values of the attributes of the block terminals NT0002 (pic2).
Can I display the pin numbers in the drawing and report?
76 Kudos
Post 4 of 5
10-11-2012 03:59 AM in reply to: galashkina
Can you post the image of pic2. I do not see it.
Bob Hanrahan
Ace User since 1998
20 Kudos
Post 5 of 5
10-11-2012 04:41 AM in reply to: galashkina
pic1=pic1+pic2
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
