AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Attribute update to match filename
1 REPLY 1
s1006771
334 Views, 1 Reply
I was wondering if someone could help me write a lisp that takes the name of the file and replaces an existing attribute with the name of the file.  Basically, have a attributed title block with a number of tags, and need to change two tags in the attributed block to be the dame as the filename.
1 REPLY 1
Wheelie22
in reply to: s1006771
					;change attrib
(defun C:CHAT (/ BNAME ANAME VAL1 VAL2)
  (setq
    BNAME (getstring "\nBlock name      \(all = enter\) : ")
    ANAME (strcase
	    (getstring "Attribute name  \(all = enter\) : ")
    VAL1  (getstring
	    t
	    "Search value    \(all = enter / all empty = \"empty\" \) : "
    VAL2  (getstring t "New value : ")
  )					;s
  (CHATZ BNAME
	 ANAME
	 VAL1
	 VAL2
  (princ)
					; Assoc funktie
(defun DXF (N ED) (cdr (assoc N ED)))
(princ)
					;change attrib
(defun CHATZ (BNAME ANAME VAL1 VAL2 /)
  (setq
    SEL	(ssget "X" '((0 . "INSERT")))
    CNT	(sslength SEL)
    TEL	0
  )					;s
  (while (/= CNT 0)
    (setq
      EN1  (ssname SEL (1- CNT))
      END  (entget EN1)
      BNAM (DXF 2 END)
      EN1  (cdar END)
      EN1  (entnext EN1)
    )					;s
					;check BLOCK name
    (if	(or (= BNAME "") (= (strcase BNAME) (strcase BNAM)))
      (while (and (/= EN1 NIL) (/= "SEQEND" (DXF 0 (entget EN1))))
	(setq END (entget EN1))
	(if (= "ATTRIB" (DXF 0 END))
	  (progn
	    (setq
	      ED1 (DXF 1 END)
	      ED2 (DXF 2 END)
	    )				;s
					;check TAG name
	    (if	(or (= ANAME "") (= ANAME ED2))
					;check val
	      (if (or (= VAL1 "")
		      (= VAL1 ED1)
		      (and (= VAL1 "empty") (= ED1 ""))
		(progn
		  (setq
		    D	(assoc 1 END)
		    D1	(cons 1 VAL2)
		    E5	(subst D1 D END)
		    TEL	(1+ TEL)
		  )			;s
		  (entmod E5)
		  (entupd (cdar E5))
		)			;p
	      )				;i
	    )				;i
	  )				;p
	)				;i
	(setq EN1 (entnext EN1))
      )					;w
    )					;i
    (setq CNT (1- CNT))
  )					;w
  (princ "Number changed : ")
  (princ TEL)
  (princ "\n")
  (princ "Value changed : ")
  (princ VAL1)
  (princ " to ")
  (princ VAL2)
  (princ "\n")
  (princ)
Use CHAT to do it manualy.
Use CHATZ like this :
(defun C:LAZY-S1006771 ()
   (load "chat")
(setq DWGN (getvar "dwgname") BLOCKNAME "ARRANGEMENT" ATTRIBUTENAME "SECTION" ) (CHATZ BLOCKNAME ATTRIBUTENAME "" DWGN) )
 Change block and attribute name as you like.
You can copy this line for other attrinutes and/or blocks:
  (CHATZ BLOCKNAME ATTRIBUTENAME "" OtherValue)
”Boost
