AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ATTREQ not resetting in Swap
1 REPLY 1
hkim
239 Views, 1 Reply
The Swap command does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion.
Hyun Kim
Powell Electrical Mfg. Co.
1 REPLY 1
in reply to: hkim
Hyun, You're right. I'll log this in the defect queue and see if this can be fixed in the next release. Nate. "hkim" wrote in message news:5656315.1081954376458.JavaMail.javamailuser@localhost... > The Swap command does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion. > > Regards, > Hyun Kim > Powell Electrical Mfg. Co.
”Boost
