<hanchris> wrote in messageI
href="news:6062248@discussion.autodesk.com">news:6062248@discussion.autodesk.com...
think I understand it; but I would like to know if there is a way we can do
the following, either with AutoCAD: Electrical 2009 proper or with a LISP
code, probably as a user post.
Without going into all the details we
have a assembly that is made up of 20+ different parts. This is no big deal,
as I know I could use assembly/sub-assembly relationships in the catalog and I
believe this translates to multiply catalog too, right?
Well we would
like to take those parts and generate them in a list of their own, without the
assembly, listed in the report. I believe I could do this in a LISP code since
under the scratch database "Parent/Child" column there is 1,2, & 99, for
Parent, Child, & sub-assembly respectively, right? My question can I do
this without any additional code and if not can I do this in a report, as a
User Post?
Now, to expand on this question, can I then take that above
assembly and make it a sub-assembly for an another assembly? I will then want
to do the same thing as above; but strip out the sub-assembly, in a different
report.
So, to reiterate, I would really like to know if I have access
to the "Parent/Child" variable in the "User Post" list or if there is some
other way to JUST do a report on a assembly or sub-assembly?
I will
probably try it, even if I do not hear an answer; but it takes me longer, then
most here to work through code, so I want to know if this is information you
are willing to share.
Thanks you,
Chris
