AutoCAD Electrical Forum
Ask, how to make this "block"
4 REPLIES 4
hyre_rye
440 Views, 4 Replies
Dear Expert,
could you tell me, how to make the "block" as attached.?
I have tried to look it up on google, but I have not found it.
please help me.
Thanks a lot,
Hery
4 REPLIES 4
Wheelie22
in reply to: hyre_rye
This drawing contains a hatch with 1 block (SEC_FLAG_mm-TEST) 2 times on it. In fact every drawing is a block, but if you use attributes they must be loose Attribute definitions in this DWG, when you insert these they are normal attribites you can edit.
In your drawing (test-drg) are 2 blocks inserted with attributes in them, so if you insert this drawing (as a block) into another you can not edit these attributes. So do you want this to be editdable explode the 2 blocks and change every attribute to a different name.
I see your blocks in there are wrong they have 2 attributes with the same tag, all the different attributes must have a different tag.
So give them a different tag like 1- / 2- / 3- and 4-, the prompt and default can be the same.
hyre_rye
thanks for the info,,
btw, I just want to ask, how about make the attributelike that ? see the arrow on the attachment.
so, we can edit the attribute.
Wheelie22
That is a Dynamic Block, I never made 1, look in the help.
hyre_rye
hi Wheelie22,
thanks for your help.
now I have started to understand the Dynamic Block.
it's so useful for me.
”Boost
