Looks like there is not a work-around to this. When a drawing is marked "ref
only", then it is totally excluded from being processed and having its data
(including SHEET attribute value) pulled into the project's scratch database
file. The little AutoLisp utility you're trying to use accesses a global
variable "GBL_wd_prj_ixlst" that is constructed from key data pulled from
the scratch database. So, if the ref-only dwgs are not in the database, then
this global will not have any relevant data for the AutoLisp utility to grab
(for a ref-only dwg).
I believe the solution is to either manually annotate these title blocks or
"unmark" these drawings as reference-only and let them get included in the
project's processing. Sorry!
Nate.
wrote in message news:5104614@discussion.autodesk.com...
Nate,
Is there a possibility to include sheets who are marked "This drawing is for
reference only (will not be processed)" to also show the "next..." and
"prev...." values?
What is my problem:
The first page is the title page, the next pages are the index. There is no
need to process them every time, so I have marked in their properties the
above mentioned item.
Now when I update the title block the lisp ignores these drawings and
returns " " as value for "next...." and "prev...."
