I am still working on the P&ID conversion. Finally have some time to look at a few things. One question on parent/child tagging....
I have instruments that will be inlne, that are then connected to an offline display or transmitter. Example, a pressure transmitter. The instrument tag would be PI... but the transmitter needs to be PIT. I want the PIT to be a child of the PI, but when I select the parent, it reverts the tag back to the PI. And if I manually change the tag to PIT... it loses parent child relationship.
Is there any known trick to pull this off?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by dougmcalexander. Go to Solution.
AutoCAD Electrical connects parent to child via the tag, so that will be a problem. You might be able use the WDTAGALT option, if you are not using this already to link to a schematic component. You can enter the alternate tag of the same device in the WDTAGALT attribute of each related device.
Thanks Doug,
I feared that might be the answer. Eventually we do want to link to our schematics, so I think I may have to find a workaround to this. I'll have to come up with some creative way of defining the Family portion of the tag for the child component.
Chris
Chris Benner
