AutoCAD Electrical Forum
Another weird tagging question...
2 REPLIES 2
cbenner
315 Views, 2 Replies
I am still working on the P&ID conversion.  Finally have some time to look at a few things.  One question on parent/child tagging....
I have instruments that will be inlne, that are then connected to an offline display or transmitter.  Example, a pressure transmitter.  The instrument tag would be PI... but the transmitter needs to be PIT.  I want the PIT to be a child of the PI, but when I select the parent, it reverts the tag back to the PI.  And if I manually change the tag to PIT... it loses parent child relationship.
Is there any known trick to pull this off?
2 REPLIES 2
dougmcalexander
in reply to: cbenner
AutoCAD Electrical connects parent to child via the tag, so that will be a problem.  You might be able use the WDTAGALT option, if you are not using this already to link to a schematic component.  You can enter the alternate tag of the same device in the WDTAGALT attribute of each related device.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
cbenner
in reply to: dougmcalexander
Thanks Doug,
I feared that might be the answer.  Eventually we do want to link to our schematics, so I think I may have to find a workaround to this.  I'll have to come up with some creative way of defining the Family portion of the tag for the child component.
Chris
”Boost
