AutoCAD Electrical Forum
Angled wire spacing
4 REPLIES 4
svend007
507 Views, 4 Replies
Angled wire spacing
Just wondered if there is a way to control the spacing of the angled wire inserted after another is already present on a particular component. It seems to default to 2.54mm, which is pretty useless when working in mm on a 1 or 2mm grid (snap).
I'm talking about the vertical spacing to the initial wire above or below the angled one added.
Cheers,
Pete B.
4 REPLIES 4
dougmcalexander
in reply to: svend007
The angled wire offset is controlled by the Feature Scale Multiplier on the Drawing Format tab of Drawing Properties.  Be careful if you change this value.  It changes the scale of all symbols.  Note: Don't use the FSM to scale inches to metric or vice versa.  This affects the wire trap distance and can cause irregularities with wire numbering, cross-referencing, etc.  I recommend no more than a value of 2 (doubling the size of symbols) and no less than 0.5 (scaling symbols by half).
If you want to exercise total control of the angled wire offset, use the angled wire option under Insert Wire instead.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
If you "cheat", and set the wire trap distance to 0.625, you'll get it at 2.5 mm.
The default value of 0.635 seems like a typo for "mm full size"?
Use the command (setq GBL_WD_TRP 0.625) to set a different trap distance.
I guess you can try to incorporate this into wd.env also. Haven't got the time to have a closer look at that right now.
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
svend007
in reply to: rhesusminus
Thanks for the replies guys.
I have the FSM set to 1 and 'mm full size selected, if I start messing around with the scale of my components, then they'll be off the grid (snap) too.
Ideally, needs to be a multiple of 1mm. ie 2 or 3mm spacing, don't want to have to go down to .5mm snap points.
Easiest to use the 45 degree wire, then I get the correct spacing.
Thanks again,
Pete B.
BTW, I have to say this seems a bit of a 'fudge' for metric users, especially if u use snap on which I'm guessing most do.
dsnodgrass
Trond,
As you suggested to the OP I added SETQ:GBL_WD_TRP,'0.03125 to the WD.env file.
After starting ACADE I check the variable:
Command: !GBL_WD_TRP
0.03125
Run the command "aewire" and check again:
0.025
I run this lisp code:
(if (not GBL_WD_TRP)
	(princ (strcat "\nGBL_WD_TRP set to: " (rtos (setq GBL_WD_TRP 0.03125)) "\n"))
	(princ (strcat "\nGBL_WD_TRP changed from " (rtos GBL_WD_TRP) " to " (rtos (setq GBL_WD_TRP 0.03125)) "\n"))
Check again:
0.03125
0.03125
I have also tried to make this change in the wd_load.lsp file but the first use "aewire" overwrites it again.
Can you think of another routine that I might be able to use the lisp code in to overwrite the aewire's initializations of this variable?
DS
”Boost
