I am trying to alter the way the "Update Signal References" command works (AEUPDATESIGREF) specifically for signal arrows
I have noticed that by default, the command places the prompt value for the XREF attribute in front of the XREF attribute value (the default for the prompt value is either "from" or "to" depending on whether the signal arrow is a destination or source respectively). So the result is "to %S-%N".
I would like to alter the command to place the XREF attribute value in brackets. The result for the XREF attribute after running AEUPDATESIGREF would be "[%S-%N]".
Is there a built in way to alter the behavior?
If not, does anyone know which lisp (or other) files I could modify to alter the behavior? I believe the AEUPDATESIGREF command may make use of either the wd_xref_doit or ace_sig_update function API function.
