AutoCAD Electrical Forum
aligning text attributes
19 REPLIES 19
Message 1 of 20
grahamLewis2010
8540 Views, 19 Replies
A simple thing! there must be an easy way (I hope) to align attributes of various components ... just like aligning wire numbers or the components themselves... I just haven't been able to see it PLEASE PLEASE can someone help... I need my diagrams to look nice....
thanks in advance
Graham
Graham
19 REPLIES 19
Message 2 of 20
The attribute move command allows you to select attributes from multiple blocks and move them all at once.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 3 of 20
Hi Doug,
thanks again for responding... yeh got that and have been using it but what I really want to do is click items and have them align accurately its amazing how sharp the human eye is in detecting slight offsets and how hard it is to align separate text objects.. it seems disappointing to me! especially when it does it with other items such as wire no's ...
Graham
Graham
Message 4 of 20
in reply to: grahamLewis2010
Graham,
Attached is a small LISP routine that can be used to align attributes on
blocks. It works similar to the Acade Align Component command. It does not
work with Align and Fit text justifications though (I didn't take the time
to add that support).
It is not fully tested and is being supplied as-is, but it works on basic
attributes and can be used to align attributes on either the same block or
different blocks. It will also work on any drawings, they do not need to be
Acade drawings.
Steve
"NickMcGarry2994" wrote in message news:6328030@discussion.autodesk.com...
> Hi Doug,
> Graham
Message 5 of 20
Hi Steve,
I have tried your autoLISP file but couldn't get it working... it loaded Ok but when i typed AATTR at the command prompt it returned "Unknown command "AATTR"... any ideas?
thanks
Graham
Graham
Message 6 of 20
Graham,
Looks like the first file I attached got corrupted. I have re-attached the
file to this post. Hope this one gets posted Ok.
Steve
"NickMcGarry2994" wrote in message news:6342138@discussion.autodesk.com...
> Hi Steve,
> thanks
> Graham
Message 7 of 20
Graham,
Looks like the first file I attached was corrupt. I tried posting it again
and it was also corrupt. I think it might be the encoding I used when I
saved it, so I am trying to post again here with a different encoding, hope
this works :).
Steve
> Hi Steve,
> thanks
> Graham
Message 8 of 20
Hi Stave,
and thanks again... I am afraid it still didn't run... same problem.. any chance you could email the file directly to me?
graham@c-designs.co.uk
graham
Graham
Message 9 of 20
Graham,
Ok, Looks like there is an issue when I am attaching a text file, the files
are getting corrupted. I have reattached the file here in compressed
format, that should take care of the corruption issue.
If anyone has a suggestion as to why when I attached a text file it is
getting corrupt, it would be appreciated. After the file gets sent to the
NG, when I try and view it, it looks as if all the returns/linefeeds are
removed from the file. I tried to resave the file with UTF-8 encoding, but
had the same issue after uploading it.
Steve
> Hi Steve,
> thanks
> Graham
Message 10 of 20
Steve,
manay thanks!
that's brilliant.. works very well.
Graham
Graham
Message 11 of 20
Steve,
many thanks!
Graham
Graham
Message 12 of 20
I can't say why it appears to corrupt the file but I would suggest always
zipping any files you want to attach. I believe that file attachments go
through some sort of virus checking and some are filtered out.
Pat Murnen
"Steve" wrote in message
news:6342320@discussion.autodesk.com...
Graham,
Steve
> Hi Steve,
> thanks
> Graham
Message 13 of 20
Thanks Steve!
Message 14 of 20
Great lsp. Helps a lot. Thank you
Message 15 of 20
JoEthr
Nice Steve!
Did ACADE 2016 add an align attribute function? I feel like I read that when I was reading about what's new in 2016
ACADE 2015
Windows 7 64 bit
Message 16 of 20
deen_b16
This was very helpful. I would like to say thanks.
Message 17 of 20
NateWa
in reply to: deen_b16
Steve,
I have been using this lisp file for a while now and love it, thank you for posting it. Just wondering if you have made any changes to the original file that you posted on this thread? It would be awesome to have the window function incorporated in this lisp.
Message 18 of 20
jorge.avalosZAHC3
Thank you so much!
Works great!
Message 19 of 20
I need LISP for Attribute text justification to change at at time all attribute text, please can anyone to help
email: zakirsyds@gmail.com
 thank you
Message 20 of 20
 thank you
”Boost
