ACADe 2008 SP1: After the build is complete, the PLC “CAT” attribute is invisible no matter what I do. Toggling it in the show/hide attributes dialog does nothing (and it was already set to be visible anyway). The command attdisp=on shows a lot of invisible attributes, but not the PLC CAT (nor the MFG, DESC, LINE1, or LINE2 attributes either). I can survive without the other attributes, but I really need CAT to show up.
Can any of you Autodesk folks please try to reproduce this bug? (and then fix it)
