Rob, Unfortunately we have tried what you have described (the selected fields that you elude to are displayed in a screenshot in the attached file). What is not readily clear though is which fields from the list tie in with those from the "W0" table.
We select the same fields (items) to process from the list as we have in the past w/ 2004, but under 2005 they display no info. Bug???
None the less, Thanks for the feedback.
