AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
AE2005 30 Day Trail Installation Problem
15 REPLIES 15
Message 1 of 16
kcurry32
303 Views, 15 Replies
I'm getting several error in AE2005 after it's installed.
One is a unhandled exception error EO6D7363 at address 7C57E592h associate with file:
C:\Program Files\Autodesk\Acade 2005\Acade\wd_mdb.arx
Also, a wddemo.mdb file appears to be missing.
What do I do?
15 REPLIES 15
Message 2 of 16
in reply to: kcurry32
Do you have a previous version of AutoCAD Electrical installed or perhaps Via WD installed on your machine? What exact steps did you take that caused you to encounter the problem? Just trying to get a little more information on your situation before providing suggestions. "kcurry32" wrote in message news:21119730.1092953489620.JavaMail.jive@jiveforum2.autodesk.com... > I'm getting several error in AE2005 after it's installed. > > One is a unhandled exception error EO6D7363 at address 7C57E592h associate with file: > > C:\Program Files\Autodesk\Acade 2005\Acade\wd_mdb.arx > > Also, a wddemo.mdb file appears to be missing. > > What do I do?
Message 3 of 16
kcurry32
Al,
I did have Autocad Electrical 2004 30 day trail installed before, but I uninstalled it before I installed ACE 2005 30 day trail. I also have Autocad 2000i installed on my PC (network version). I'm running Win2000 SP3.
Message 4 of 16
It could be the jet database drivers that AutoCAD Electrical uses. These drivers can be re-installed from a supplied install on the CD. The Jet drivers are in the file: JET40sp5_w2k.exe. This file is on the CD in the following location: \Bin\ACADFeui\Support\jet4sp5 You might check with you IT person there to see if there is anything on your machine that installing this Jet driver might interfere with before installing it. I have never ran into anyone having any problems with this though. This is a Microsoft Jet driver install. The missing file you mentioned in the original post is missing because this WD_MDB.ARX is required to create this file. Steve "kcurry32" wrote in message news:23588197.1093981372173.JavaMail.jive@jiveforum2.autodesk.com... > Al, > > I did have Autocad Electrical 2004 30 day trail installed before, but I uninstalled it before I installed ACE 2005 30 day trail. I also have Autocad 2000i installed on my PC (network version). I'm running Win2000 SP3. > > Thanks
Message 5 of 16
kcurry32
Steve,
Thanks for the response. I've completely uninstalled and reinstalled the application and still have the same problem. When the application loads I get the following message (see attached screen shot jpeg). I also get this message when I issue any command (like "open project" or "insert rung". I'm down to 16 day on the demo and I haven't learned anything yet!!!
When I tried to install the jet engine file, I got the following message (see attached screen shot jpeg). Basically, it won't install because of the of the w2k SP3. It can only install on SP1. My computer only has MSOffice97 installed, could this be an issue with the jet engine?
Thanks for your help.
Keenan
Message 6 of 16
kcurry32
Steve,
I forgot my file attachments. Here the exception error message that I get.
Keenan
Message 7 of 16
kcurry32
Steve,
Here's the Jet Engine error that I got when I tried to install the Jet engine on the CD.
I downloaded the late Jet Engine 4.0 SP8 from Microsoft's website. It installed but doesn't appear to help the problem. Another interesting thing is that if I try to open a *.mdb file from an Acade directory my system can not open it it MSAcess97. This is before and after the Jet Engine update. I get a dialogue box that says "unrecognized database format" appears listing the file that I tried to open. I'm wondering if this problem is contributing to my issue.
Keenan
Message 8 of 16
testsubject
Nate, Steve, or Jarred can correct me here, but I think that the MDB is saved as an Access 2000 file. This will not open with Access 97.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 9 of 16
Testsubject is correct, the .MDB files with Acade are saved in a Access 2000 format. Running AutoCAD Electrical with Access 97 installed should not be a problem, but I can't say for sure since this was not testing in the Acade 2005 release since Access 97 support was dropped because of it being so old. I will see if I can come up with anything else, but I don't have Access 97 to test with. Steve "kcurry32" wrote in message news:6200077.1094053794537.JavaMail.jive@jiveforum1.autodesk.com... > Steve, > > Here's the Jet Engine error that I got when I tried to install the Jet engine on the CD. > > I downloaded the late Jet Engine 4.0 SP8 from Microsoft's website. It installed but doesn't appear to help the problem. Another interesting thing is that if I try to open a *.mdb file from an Acade directory my system can not open it it MSAcess97. This is before and after the Jet Engine update. I get a dialogue box that says "unrecognized database format" appears listing the file that I tried to open. I'm wondering if this problem is contributing to my issue. > > Keenan
Message 10 of 16
What rights do you have on this system? Also, I believe that SP4 is out and I wonder if that might help anything? Other than that, as far as I can remember every time we had seen this wd_mdb.arx error updating the jet drivers, or old DAO component drivers fixed the issue. As Steve and testsubject mentioned, the database is shipped in 2000 format and Office 97 was not tested as it is 7+ years old now so we cannot be completely sure that, that isn't causing an issue. Maybe another user with 2005 has Office 97 installed also and can let us know if they are seeing this issue...... -- ---- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc. -------------------------------------------------------- "Steve Kemp (Autodesk)" wrote in message news:413616b5$1_2@newsprd01... > Testsubject is correct, the .MDB files with Acade are saved in a Access 2000 > format. > > Running AutoCAD Electrical with Access 97 installed should not be a problem, > but I can't say for sure since this was not testing in the Acade 2005 > release since Access 97 support was dropped because of it being so old. > > I will see if I can come up with anything else, but I don't have Access 97 > to test with. > > Steve > > "kcurry32" wrote in message > news:6200077.1094053794537.JavaMail.jive@jiveforum1.autodesk.com... > > Steve, > > > > Here's the Jet Engine error that I got when I tried to install the Jet > engine on the CD. > > > > I downloaded the late Jet Engine 4.0 SP8 from Microsoft's website. It > installed but doesn't appear to help the problem. Another interesting thing > is that if I try to open a *.mdb file from an Acade directory my system can > not open it it MSAcess97. This is before and after the Jet Engine update. > I get a dialogue box that says "unrecognized database format" appears > listing the file that I tried to open. I'm wondering if this problem is > contributing to my issue. > > > > Keenan > >
Message 11 of 16
Keenan, Here is something else that you can try. Acade relies on MDAC for some of our database access, so we can try updating this on your machine. It would be best if we install version 2.5 of MDAC, since in versions 2.6 and on there was some components removed that we require. Here is a link to MDAC 2.5: http://www.microsoft.com/downloads/details.aspx?familyid=c57692e9-dde7-4a60-b586-5d4fd6794db6&languageid=f49e8428-7071-4979-8a67-3cffcb0c2524&displaylang=en After you install this, try Acade again. If you still have a problem, you might have to install the Jet drivers again, since the MDAC 2.5 does come with some of the Jet components also. I hope this help. I am running out of ideas. It could be an issue with Access 97 being on the machine since Acade 2005 does not support Access 97 and has moved to supporting Access 2000. If possible, you might see if there is another machine that you could install Acade 2005 onto, and see if it works there. Steve "kcurry32" wrote in message news:6200077.1094053794537.JavaMail.jive@jiveforum1.autodesk.com... > Steve, > > Here's the Jet Engine error that I got when I tried to install the Jet engine on the CD. > > I downloaded the late Jet Engine 4.0 SP8 from Microsoft's website. It installed but doesn't appear to help the problem. Another interesting thing is that if I try to open a *.mdb file from an Acade directory my system can not open it it MSAcess97. This is before and after the Jet Engine update. I get a dialogue box that says "unrecognized database format" appears listing the file that I tried to open. I'm wondering if this problem is contributing to my issue. > > Keenan
Message 12 of 16
kcurry32
Hey Guys,
I tried install MDAC 2.5, but it would not install because it recognized that the files were already installed with W2k. I also tried to install MDAC 2.8 (the latest) and then reinstalling Jet 4.0 SP8 (as the MS wedsite suggested), but again, no luck. Anymore suggestions?
It's a little disappointing that the install relies on a later version of a program (ACC2000), as I understand you'll are saying. If this is the case, I'm shot, because Hallmark Cards (my employer) still uses Office97 as it's default office application and has no plans of changing anytime soon. What if I didn't have Office installed at all? Would this help (even though I have no way of installing it again myself, it's an IT controlled program)?
Thanks for all your suggestions so far. I'm hoping one of them will lick my problem (I only have 14 more days to try this program out before I'm able to recommend it or not to my staff and EE peers within the corporation. I'd sure like to try it first so that I can give it a fair shake, because your marketing department makes it sound very apealing to our needs.
Thanks again.
Keenan
Message 13 of 16
Keenan We do not believe that the Office '97 should be causing an issue, we were just saying that since it is such an old product we no longer test with it and therefore do no know of all the results or affects that could happen. Office is not even required to run Electrical, so the only thing you would have to do for '97 is convert any of the mdb files if you would want to edit them in access. Have you attempted to install this on any other machine? Also, what rights do you have? It sounds like your company is fairly strict and IT monitors things pretty closely. If that is the case, you may not have the full Administrator rights that are needed to install the program correctly. My next suggestion would be, get IT involved, have them login to the machine so that they have full admin rights on the machine, then run the "repair" option from the CD. Let's give that a try and see what happens. If you could also get someone else to try installing it, or take the CD home and install it there, that could help narrow it down to something on that particular machine, but again, no matter what machine you go to install on, you must have full admin rights to install the program. -- ---- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc. -------------------------------------------------------- "kcurry32" wrote in message news:25731089.1094247057038.JavaMail.jive@jiveforum1.autodesk.com... > Hey Guys, > > I tried install MDAC 2.5, but it would not install because it recognized that the files were already installed with W2k. I also tried to install MDAC 2.8 (the latest) and then reinstalling Jet 4.0 SP8 (as the MS wedsite suggested), but again, no luck. Anymore suggestions? > > It's a little disappointing that the install relies on a later version of a program (ACC2000), as I understand you'll are saying. If this is the case, I'm shot, because Hallmark Cards (my employer) still uses Office97 as it's default office application and has no plans of changing anytime soon. What if I didn't have Office installed at all? Would this help (even though I have no way of installing it again myself, it's an IT controlled program)? > > Thanks for all your suggestions so far. I'm hoping one of them will lick my problem (I only have 14 more days to try this program out before I'm able to recommend it or not to my staff and EE peers within the corporation. I'd sure like to try it first so that I can give it a fair shake, because your marketing department makes it sound very apealing to our needs. > > Thanks again. > > Keenan
Message 14 of 16
kcurry32
Jared,
I will try to install it on another machine that I have admin rights on or have my IT guy do it for me. I do have full local admin rights on the machine that I installed it on.
Is there a possibility that I have a corrupt wd_mdb.arx file? When I run Acad 2005 and try to load applications in the Acade directory (all the *.arx files), all of them load but the wd_mdb.arx file. I'm just wondering why it's not loading properly.
Keenan
Message 15 of 16
Keenan, When you say you load all the ARX files from Acade, are you loading all of them from the folder: C:\Program Files\Autodesk\Acade 2005\Acade What exact message does it give you when you try and load the wd_mdb.arx file? How are you tring to load these ARX files? Using APPLOAD, type in the (arxload "{path}/wd_arx"), or the ARX command from the command line? I was just wondering, because sometime each of these will give a different error message during loading and some are more informative then others, so you might try all these ways of loading this file. I seem to be able to load this file on my Acad 2005 fine. It looks like if there was en error during loading, you would see this when Acade starts up though. And if this file does not get loaded during the initialization of Acade, a crash would not occur in this arx, since it would not be loaded. As for needing Office installed, only my main machine has Office installed, the other machines have no version of Office installed on them at all. Steve "kcurry32" wrote in message news:10593240.1094567492822.JavaMail.jive@jiveforum1.autodesk.com... > Jared, > > I will try to install it on another machine that I have admin rights on or have my IT guy do it for me. I do have full local admin rights on the machine that I installed it on. > > Is there a possibility that I have a corrupt wd_mdb.arx file? When I run Acad 2005 and try to load applications in the Acade directory (all the *.arx files), all of them load but the wd_mdb.arx file. I'm just wondering why it's not loading properly. > > Thanks, > Keenan
Message 16 of 16
kcurry32
Steve,
First of all, I did get Acade 2005 to load and run fine on another machine. That machine also has Office97 on it, so you are definitely correct that Office97 has nothing to do with my issue.
The dialogue box for the error says in the title bar, "Exception in C:\Program Files\Autodesk\Acade 2005\Acade\wd_mdb.arx ARX Command"
Body of dialogue Box:
Unhandled Exception E06D7363 (eo6d7363h) at address 7C57E592h
This is the same message that occurs when I start Acade. Therefore, whether I start Acade or Acad 2005 and then launch the APPLOAD command for that ARX file (wd_mdb.arx), I get the same message.
Hopefully, we can still find the problem with the application running on my own PC. The other PC where Acade installed fine is a little inconvenient to use because it is the departments laptop.
Keenan Curry
”Boost
