Is this still a bug?
The default Catalog does not update when installing additional Manufacturers Catalogs in ACADE 2013.
Is there a solution or workaround?
Ok, seeing as no one can supply a quick answer, let me ask this. If installed on a second machine with the desired manufacturers selected during install. Can you simply cut and paste the default_cat.mdb into the first machine?
I do not want to reinstall on first machine, too many custom features.
This problem is holding me up. Thanks.
Hi MTSII,
Yes you can copy the database over from a working machine.
Not sure why you are having issues adding the manufacturers from the add/ remove features in the Control panel.
I have installed the manufacturers from the 2013 media for clients hundreds of times and I have only seen issues with Anti Virus (AVG specifically), Windows UAC, and Domain Admins (that were not true admins).
I have seen corrupt downloads a number of times but it won't even install the product if that's the case.
I would suggest Disabling the Anti-virus, make sure the UAC is set to nothing, and make sure you are using a local admin (which is what all installs should be done with)
Sorry IT guys that want to control everything, but that's the truth unless the domain admin is a Full Admin on the Machine, it just won't install things properly. ( I Don't mean this to be harsh, but I hate that companies lock everything down to the point you can't even install the products you need to do your work.)
I hope this helps,
James Alger
SolidCAD
