AutoCAD Electrical Forum
adding terminals to terminal strip editor
1 REPLY 1
244 Views, 1 Reply
 At the moment when i add a terminal to an exisitng terminal strip in terminal Strip editor or any other type of equipment such as end stops and press the Insert tab in layout preview it will insert the hole terminal strip again and not just the equipment i have added. Does anyone know how to stop it from completly adding the hole terminal strip again and only allow what i have added to that terminal strip.
Adrian
1 REPLY 1
ronbotkin
When you are on the Layout Preview page you can use Rebuild instead of Insert but those are your only options.
”Boost
