I needed to add some new Allen-Bradley 1769 analog modules. I have suceeded in doing so, but I have questions about the process I used.
1. In the ace_plc.mdb database, added module information to the table: allen-bradley_1769_analog input
2. In the ace_plc.mdb database, added module information to the table: allen-bradley_1769_analog input_Data
3. Opened PLC Database File Editor under the Schematic-->Other tools tab, and entered attributes and terminal types
4. Went back and added module info to the default_cat.mdb
Were all of these steps necasary? Or is there an easier way? Everything works fine, and the modules insert properly, but it seems like a convoluted process.
Your procedure is a little vague. Did you cut & paste a similar module or recreate one from scratch?
Note: Right-click on a module in the PLC Database Editor for options.
a combination
first module was a 1769-OF4 4 channel analog output--I copied a 1769-OF2 and added the other needed terminals and labels. Note---there are 2 of versions you have to make---1 for current, and 1 for voltage
other module was a HI 1769-2WS 2 channel weigh module. This is actually from a 3rd party--Hardy Instruments. Nothing like this in the database, so I had to do this one from scratch
Right click in the PLC editor alows you to add new module and number of terminal------but you have to specify connection direction and labels in the following screen
Like I said, i am sure there is an easier way
Why are you Copying and Pasting in the Access database?
Just use the PLC Database editor in AutoCAD Electrical. (looks like you were using it for part it any way.)
Find the Card you want a copy of right click on it select copy, then right click paste.
After that right click and Rename the card.
You may also need to change the module specs and add/remove any unnecessary terminals.
You should add the catalog number to the Default_cat.mdb, and the foot print lookup, but you only need to do that if you want to show more then a box repersenting the plc (most people just use the panel layouts for general layout and position).
I hope that helps,
James Alger
SolidCAD
