Go to the AutoCAD Electrical help and in the Index tab, type in Pin Lists. Select Advanced and away you go. This will get you the info you need. Take a look at the other pin list help topics as well. In the help file, you can also select "Advanced Productivity>Creating automated pin assignments" and it will get you to the same area.Good luck with the class.
