AutoCAD Electrical General Discussion
Active Contributor
0 Kudos
Post 1 of 3
Add Spacer Line to parametric PLC
122 Views, 2 Replies
01-19-2012 01:05 PM
I regurally add a spacer line to a parametric PLC through the PLC to spreadsheet utility. Is there a way to add the spacer after a PLC has already been inserted?
I'm coming back to an older project, & need to add some space for a new circuit between I?O points.
All help appreciated,
There is no way to update your already inserted PLC module, but have a look at the "Stretch PLC Module" command. It might help you achieve what you want.
THL
150 Kudos
Post 2 of 3
Re: Add Spacer Line to parametric PLC
01-20-2012 12:11 AM in reply to: Pertech-LLC
THL
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Active Contributor
0 Kudos
Post 3 of 3
01-20-2012 06:51 AM in reply to: Pertech-LLC
That is the command I was looking for.
Thank You
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
