I regurally add a spacer line to a parametric PLC through the PLC to spreadsheet utility. Is there a way to add the spacer after a PLC has already been inserted?
I'm coming back to an older project, & need to add some space for a new circuit between I?O points.
All help appreciated,
Solved by rhesusminus. Go to Solution.
There is no way to update your already inserted PLC module, but have a look at the "Stretch PLC Module" command. It might help you achieve what you want.
THL
