Show only
Search instead for
I had to add a rung in my ladder but when I try to add a rung in a ladder, I see the message “1 inserted” however I could see no rungs added. My ladder width is 4” and the spacing is 1”. My grid is 1” and my snap is 0.5”.
What is the setting I am missing here?
What are the other settings I should watch for when play around with ladders?
The onsnaps were on so I turned off every thing, but still it didn't show the inserted line, and same as I mentioned above, it shows "1 inserted" in the command.
mm...what else?
Just below the Folder Icon (Upper left corner of the display) you should see the light bulb and to the right the name of the current layer. If this light bulb is not on you will not see and lines drawn. You may also check to see if the default wire (rung) layer is turned off. Too the left of the light bulb you should see what looks like a stack of papers icon. Click on that and you'll get to the layer properties manager dialog. if any light bulbs are off indicates the layer in not being displayed. Hope this helps.
Dave
Thanks for the details. The layers are ok, they look as they should be.
My problem is, I could add a wire between 2 rungs manually, and its visible. Only the add rung is not working.
Your sample Test.dwg has rungs on each line number.
I erased the rungs using the wire cutter button. Added 4 rungs using the insert rung button. All worked fine.
If you are trying to add a rung in between the line numbers you need to draw a wire. Insert rung will only place a wire on the line number.
Dave
Thanks a lot for the analysis and the reply.
I remember inserting rungs in the ACE tutorial and that's why I try to do it. Now I went back to the tutorial and got your point.
