AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Add or Remove features?
1 REPLY 1
mako68
566 Views, 1 Reply
AutoCAD Electrical 2013 installed from USB stick (Product Design Suite).
Need to modify installation (add new manufacturer data). Go to Control Panel  and select "Add or remove features" after modifying ACADE is asking to insert disc 2 of 3 of AutoCAD Electrical?
Try with USB stick...no help -> Cannot continue.
Is this known bug?
1 REPLY 1
algerj
in reply to: mako68
Hi Mako,
I have seen the Issue a few times, it seems to forget where the MSI file is.
Normally after selecting the MSI file for ACADE from the USB stick it works.
You need to select the MSI file when it asks for the disc (9 times out of 10 it is searching for the MSI fie), browse to your usb and find the MSI file below.
It should be in a location similiar to this one: (E: Drive being my USB Drive, also mine is product design suite ultimate APDSU...)
E:\APDSU2013\x64\Acade\ ACAD.MSI
I hope this helps,
James Alger
SolidCAD
”Boost
