I am converting an Autocad drawing to ACADE 2013. I've tagged a component and successfully added wire connections. Now I need to "add geometry" (using the conversion tool) wthin the symbol from the exisitng Autocad geometry. This works fine, but any text within the symbol that I want included is not. I'm not interested in them becoming attributes. they just need to be included in this electrical "symbol".
Any ideas?
Thanks, Dave W
If I understand you correctly you should be able to use the 'block editor' (Tools>Block Editor) and add the text as you would any other normal text. Let us know if that does what your after.
