Hey guys,
Does anyone know of a way that I can run a recorded action macro on every drawing within the project?
Mike
Solved by sonny3g. Go to Solution.
I have used the Project Utilities to run a script on all project drawings and in the script I had a the name of my recorded action. The only caveat was that I had to make sure that my recorded action did not require any user input to run. Otherwise, it works quite well.
Hope that helps you out.
