AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
AcePmComServer6.exe Error!! Again and again and...
21 REPLIES 21
Message 1 of 22
ColmacCadGuy
950 Views, 21 Replies
What is this error and why is it happening so much? I am running ACADE 2009 on an XP machine. I didn't have this error until I started working with terminal block footprints.
Nathan
21 REPLIES 21
Message 2 of 22
in reply to: ColmacCadGuy
Do you have a chance to send the error report to
Autodesk? If you do, please send it in and add a note this is from the
newsgroup.
Make sure your active projects exist, and make sure
that the drawings within the projects exist. This can cause an error/message
that doesn't really affect the functionality. I assume this is not what you are
getting but just want to make sure.
Pat Murnen
What
block footprints. Nathan
Message 3 of 22
ColmacCadGuy
Pat, What is the best way to submit this error to Autodesk?
Since I haven't been working on terminal block foot prints for a few days, I haven't received that error. Strange.
Nathan
Message 4 of 22
Actually, after I sent my post I found out that
AcePmComServer doesn't bring up the Error report dialog which is what I was
referring to. If you get the error again, maybe you can send me the project and
drawing(s) along with any details about what you were doing at the time. My
direct email is
href="mailto:pat.murnen@autodesk.com">pat.murnen@autodesk.com
. Also include
the AcadE version, including service packs, and your operating
system.
Pat Murnen
Pat,
What is the best way to submit this error to Autodesk? Since I haven't been
error. Strange. Nathan
Message 5 of 22
ColmacCadGuy
Wow! Ok Pat. Ill send you the error info with the next instance.
Thanks!
Nathan
Message 6 of 22
One of my users are also getting this. ACADE 2009, SP1 32bit., Windows XP SP2.
Message 7 of 22
I am interested in finding a few customers who have
this problem whom I can ask to temporarily replace some DLLs and run some tests
so I can get a clearer picture of common failure points.
If you are willing to do this and be involved in
some email discussion about your experience, can you please respond by
emailing me at
href="mailto:lee.hollingworth@autodesk.com">lee.hollingworth@autodesk.com
 telling
me:
 - ACADE version
 - Service packs
 - Operating system (if XP, whether you
use Classic view)
 - Hardware configuration
I may or may not be able to work with everyone that
responds as I am looking for unique systems, but your responses are appreciated
and will help us find a solution (right now we cannot reproduce the
problem).
Thank you,
Lee
What
Message 8 of 22
frankmoors
Dear all,
I also have the same problem, i'm not having it specific when using terminal footprints but random.
When the error appears, ACE stays up but I lose the connection with the acces database.
My machine:
Dell PWS340
WinXP professional version 2002 SP3
Intell Pentium 4 1.95Ghz
2Gb Ram
Using Windows classic menu
Performance settings "Adjust for best performance" (WinXp setting)
Today I've installed ACE2009 SP2 and will see what this will do.
Best regards
Message 9 of 22
I have had this problem since ver. 2009 was loaded. The problem shows up randomly when editing an object in a drawing when more than one drawing is open in a project. Multiple drawings can be opened on purpose when I'm flipping between drawings with the "Ctrl" "Tab" keys or if the next/previous arrow keys are pressed before the command line says the drawing is fully open. This opens the next drawing but does not close the previous drawing. The error occurs with existing projects as well as a project started from scratch. It can be a catalog edit or simply moving a schematic symbol or footprint to a new location. Once the error happens all project connectivity is lost and AutoCAD must be shut down and restarted. Once in a while the computer must be shut down because the message "AutoCAD was not installed properly, please reinstall. The reboot will fix that problem. A service report was filed with SR# 1-3660887111. Attached is a screen shot of the error. I also have a copy of the error report sent in. The system is a Dell Latitude D830, Intel(R) Core(TM)2, Duo CPU T7250 @ 2.00GHz, 2.00 GB of Ram, running windows XP Professional, Version 2002, Service Pack 3, and AutoCAD Electrical 2009 Service Pack 2.
P.S. Version 2009 is noticeably slower than 2008 while using the catalog edit function..
Message 10 of 22
HarperIntl
Hi Pat,
We recently upgraded to ACADE 2009 and started randomly getting the same errors. The machine in question is Pentium M, 2Ghz, XP SP3, ACADE SP1. I have collected a number of .txt files and screen shots related to the problem. My reseller stated that you were interested in any information related to this. Would it be ok to send the information to your email posted within this thread? Thanks!!
Message 11 of 22
Please send everything to Lee Hollingworth. Here is
a copy of his previous post on this. Pat Murnen
emailing me at lee.hollingworth@autodesk.com telling
me:
 - ACADE version
 - Service packs
use Classic view)
problem).
Thank you,
Lee
Hi
Pat, We recently upgraded to ACADE 2009 and started randomly getting the same
thread? Thanks!!
Message 12 of 22
svend007
Just wondered if there were any developements on this as I seem to be getting this quite a lot at the moment, (whilst I'm working on footprint drgs).
Cheers,
Pete B.
Message 13 of 22
svend007
I guess not then!
Message 14 of 22
We are testing a solution with several customers.
If you would like to test the solution, you can email your details to me at
Lee
Cheers, Pete B.
Message 15 of 22
svend007
Hi Lee, that would be good.
Bit busy at the moment, but should have some time over the next couple of weeks.
I'll email you.
Cheers,
Pete.
Message 16 of 22
Renorick
Same here, random occurrence, but seems to happen most while flipping through multiple pages, such as when placing signal source and destination links.
WinXP, V2002, SP3
Dell Optiplex 755, E2220 cpu @2.4ghz, 3 gb ram
Message 17 of 22
breierg
Has this issue been resolved and if so whats the solution. Just started AutoCAD electrical 2009 sp2 and now have been getting this error
Message 18 of 22
Moleander
Not sure if this will help but as a user this has been what I have obsereved.
It appears that this error occurs when a certain number of cross references has been made durring an cad session. I noticed that I could tag components and various other xref tasks and the error would occur every 3 to 6 hours depending on how much referencing I did.
Today the error occured after just 30 minutes. I realized that I had run 2 project wide electrical audit reports (with 852 warnings) befor this error happened. I then rebotted my computer and ran 3 consecutive project wide audits and was able to cause the error emidiatley.
-Nevermind hot fix available
Message 19 of 22
jhunt107
Moleander,
Could you post the link to the hotfix so the rest of can find it. Thank you.
Message 20 of 22
Go to the folliwing URL and choose the hotfix for your version of AcadE, either 2008 or 2009. They are 3rd and 4th in the list.
http://usa.autodesk.com/adsk/servlet/ps/index?siteID=123112&id=3570520&linkID=9240737
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
