AutoCAD Electrical General Discussion
Active Contributor
elprim
Message 1 of 8 (378 Views)
ACE2012 Link components & reverse component
378 Views, 7 Replies
09-11-2012 05:17 AM
Hi
What is the right way to unlink component
I have reversed the component and then I wasn't able to connect wire,
 the connection was made over component, what I make wrong
Thank for help, Vito
Kind regards, Vito
When you reversed the contacts, did you check the box to only reverse the graphics?
I've had similar problems in the past when reversing a component and found that if I didn't check that box, the attributes would also be moved but the wire direction wouldn't change.
Regards Brad
testsubject
Message 2 of 8 (375 Views)
Re: ACE2012 Link components & reverse component
09-11-2012 05:58 AM in reply to: elprim
How did you reverse the component? If you simply mirrored it, then ACE will not work properly. You have to use the "Reverse/Flip Component"Command. One way of finding it is to hover over the component and then Right Mouse Click. This command is located near the bottom.
You can use "Trim WIre" to disconnect a component from the wiring.
Bob Hanrahan
Ace User since 1998
Active Contributor
elprim
Message 3 of 8 (372 Views)
09-11-2012 06:30 AM in reply to: testsubject
Hi, I used "Reverse/Flip Component" and result is in attachment
block is VSS21 and VSS113
Thanks, Vito
Kind regards, Vito
testsubject
Message 4 of 8 (368 Views)
09-11-2012 06:36 AM in reply to: elprim
Can you send the .dwg file? I cannot see how the symbol is created done from a jpeg...
Bob Hanrahan
Ace User since 1998
testsubject
Message 5 of 8 (367 Views)
09-11-2012 06:37 AM in reply to: testsubject
Also what library are you using? IEC2, IEC4, JIC1, JIC125, etc? They all use the same file names but the drawings are different.
Bob Hanrahan
Ace User since 1998
Active Contributor
elprim
Message 6 of 8 (365 Views)
09-11-2012 06:45 AM in reply to: testsubject
I use IEC60617 and ACE 2013
Kind regards, Vito
testsubject
Message 7 of 8 (354 Views)
09-11-2012 07:43 AM in reply to: elprim
I am not sure what is wrong.
I had no trouble reversing any of these contacts.
Sorry that I could be of more help.
Bob Hanrahan
Ace User since 1998
Icemanau
Message 8 of 8 (345 Views)
09-11-2012 03:25 PM in reply to: testsubject
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
