AutoCAD Electrical Forum
ACE2012 Link components & reverse component
7 REPLIES 7
Message 1 of 8
elprim
759 Views, 7 Replies
Hi
What is the right way to unlink component
I have reversed the component and then I wasn't able to connect wire,
 the connection was made over component, what I make wrong
Thank for help, Vito
Kind regards, Vito
7 REPLIES 7
Message 2 of 8
testsubject
in reply to: elprim
How did you reverse the component? If you simply mirrored it, then ACE will not work properly. You have to use the "Reverse/Flip Component"Command. One way of finding it is to hover over the component and then Right Mouse Click. This command is located near the bottom.
You can use "Trim WIre" to disconnect a component from the wiring.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 8
elprim
in reply to: testsubject
Hi, I used "Reverse/Flip Component" and result is in attachment
block is VSS21 and VSS113
Thanks, Vito
Kind regards, Vito
Message 4 of 8
testsubject
in reply to: elprim
Can you send the .dwg file? I cannot see how the symbol is created done from a jpeg...
Bob Hanrahan
Ace User since 1998
Message 5 of 8
testsubject
Also what library are you using? IEC2, IEC4, JIC1, JIC125, etc? They all use the same file names but the drawings are different.
Bob Hanrahan
Ace User since 1998
Message 6 of 8
elprim
I use IEC60617 and ACE 2013
Kind regards, Vito
Message 7 of 8
testsubject
in reply to: elprim
I am not sure what is wrong.
I had no trouble reversing any of these contacts.
Sorry that I could be of more help.
Bob Hanrahan
Ace User since 1998
Message 8 of 8
Icemanau
When you reversed the contacts, did you check the box to only reverse the graphics?
I've had similar problems in the past when reversing a component and found that if I didn't check that box, the attributes would also be moved but the wire direction wouldn't change.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
