AutoCAD Electrical General Discussion
dougmcalexander
Message 11 of 14 (227 Views)
Re: ACE2012 - Customizing Project Description Labels
05-31-2012 09:03 AM in reply to: Outbound
Be sure that your version of Windows is set to show file extensions.  This can cause problems when renaming text files because you can't see that the extension is already there.  In that case, you may end up with projectname_wdtitle.wdl.wdl.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Active Contributor
Outbound
Message 12 of 14 (225 Views)
05-31-2012 09:42 AM in reply to: Outbound
GOT IT!
Case closed...thank you!
New Member
cbz20
Message 13 of 14 (209 Views)
09-28-2012 04:51 PM in reply to: testsubject
hello bob,
i'm very new to autocad electrical and want to know how to create save a file with .wdl extension... when i try with note pad it only has .txt extension. i'm very confused...
Employee
murnenp
Message 14 of 14 (201 Views)
09-29-2012 07:04 AM in reply to: dougmcalexander
In Notepad if you want to save a file to an extension other than .txt, in the "Save as type" drop-down list pick All Files. Then enter the file name with the extension you want, in this case the .wdl extension.
Pat Murnen
Principal Content Developer
Information Modeling and Platform Products Group
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
