Its time to sacrifice chickens again and read the goat's entrails....
...for some reason I have managed to upset the Gods of AutoCad Electrical again and my icons now look like they are from Lilliput, even on existing drawings in unrelated projects so it looks like its a global change.
The Green arrow shows what I had and I was happy with, the red arrow demonstrates what I get now for the same connector..
Basically every icon is now tiny, what have I done wrong... yes I'm a newbie...
Please be gentle
Solved by Icemanau. Go to Solution.
Right I think I have got it sussed what I think is happening is that AutoCAD has defaulted to JIC symbols rather than IEC... why it has done this I don't know, maybe I didn't sacrifice enough chickens, goats or cows...
No if there was an easy and simply way of using the right icon libraries that would be great, y'know, "I want to change library, that one will do 'click' job done"
nope looks like it's "at the rise of the moon on the night of the summer solstice with the blood of 1000 virgin fruit flies...." time again.
Did they ever figure the term "intuative"...
If you look at the attachment, you will see where ACADE check the project properties for which symbol library to use.
Mine shows that the libraries are located at J:\Autocad\Blocks with the as2 library under that directory.
I also have the iec libraries in that location but very rarely use them.
If I did need to use them, I would add them above the as2 listing but below the main directory for the blocks.
ACADE will search in the order that directories are listed, my settings will look in the \Blocks directory and then the \Blocks\as2 directory.
Check that the project settings are pointed to the correct library.
IEC has two libraries (IEC2 & IEC4) with the only difference being in the scale of the blocks. One being designed for A2-A0 sheets and the othe for A3 ond smaller.
If you need to swap a library after doing a dwg, check the Swap/Update block tool. Under 'Option B' there is the facility to change all the blocks from one library to blocks from a different library.
Regards Brad
Brad Coleman, Electrical Draftsman
Brad,
Many thanks for the info, your answer partially sorted the problem but hasn't completely sorted it if that makes sense... connectors are now the right size but the text is huge.
I suspect the real issue lies between the keyboard and the chair (PEBKAC)
Your answer did fill in some blanks.
Thanks a lot.
Gavin
