AutoCAD Electrical Forum
ACE 2013 wire layers go missing
2 REPLIES 2
JeffatSJE
360 Views, 2 Replies
Is there an issue were wire layers go missing? I am finding myself adding wire layers back when I should not have to.
Rgds,
J.
2 REPLIES 2
testsubject
in reply to: JeffatSJE
Just to respond that I have not seen this occur.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Icemanau
Only when I run the Purge All command....
As a workaround, try getting all your layers setup and then exporting the layer setup using the 'Layer States Manager'. Then when you need to add missing layers, you just import the saved layer setup.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
