AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACE 2010 x64 unable to communicate with project database service
10 REPLIES 10
Message 1 of 11
mjkasper
1619 Views, 10 Replies
After installing on Winodws 7 x64 I receive the subject error.
I have uninstalled & reinstalled.
Further details from the project database service:
Unable to connect to Access database 'C:\Users\xxx\AppData\Roaming\Autodesk\AutoCAD Electrical 2010\R18.0\enu\Support\user\PP113446-10.mdb'
I can create & delete files in the subject directory... even attempted a blank dumby mdb with the same error.
HELP!
10 REPLIES 10
Message 2 of 11
PatMurnen_Adsk
in reply to: mjkasper
I am sorry you are having trouble. This is not my area of expertise so I have forwarded this on to someone else here who should be able to help.
I will keep an eye on this posting to make sure it is followed up on.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
Message 3 of 11
MinKeng
Hi mjkasper,
Can you please start Windows Task Manager and check if acepmcomserver8 is running?
Remove all the MDB files in support folder and relaunch the application and see if it is working.
Thanks.
Min Keng
Message 4 of 11
mjkasper
in reply to: MinKeng
This is ACE 2010...
AcePmComServer7.exe is running. Should this really be AcePmComServer8?
Erased all MDB's earlier - still not luck
Message 5 of 11
MinKeng
Can you please send us a snapshot of the task dialog? Database jet engine may not work properly due to some 32bit application running in x64 OS. We need you to try the following:
  1. Go to task manager and check if acepmdb32.exe is running with acepmcomserver7.exe?
  2. If it’s not running, please execute %ProgramFiles%\Autodesk\Acade 2010\Acade\x86\acepmdb32.exe manually.
Min Keng
Message 6 of 11
mjkasper
acepmdb32.exe  was not running.  I started it manually - but still receive the project database error.
Attached snap shot of task manager is after I manually started acepmdb32.exe.
I also restarted ACADE, rebooted computer the started acepmdb32.exe, then attempted to start ACADE... all with no luck.
Message 7 of 11
MinKeng
Can you please see if the following steps resolve your problem?
1) Exit AutoCAD Electrical
2) From Start menu select ‘Run’ or go to a command prompt
3) Type in:  ‘regsvr32 c:\Windows\SysWOW64\msjet40.dll’ and press Enter.
    You should receive a Succeeded message
4) Type in:  ‘regsvr32 c:\Windows\SysWOW64\msjetoledb40.dll’ and press Enter.
Min Keng
Message 8 of 11
mjkasper
After registering both DLL's, restarting the computer, manually starting AcePmDb32.exe, then starting ACADE I still receive the same error... unable to connect to the project database.
Message 9 of 11
mjkasper
any more suggestions?  My work is backing up and I NEED to get ACADE working....
Message 10 of 11
MinKeng
I am getting some engineers to work on this for you. In the meantime, is there any other machine that can get this working first?
Message 11 of 11
mathalekar
We checked ACE2010+SP1 on Win 7 x64 bit. The software works just fine and can communicate with project database without any issues. The OS  configuration that we are testing is Win 7 x64 Enterprise. We would like to seek some help to understand configuration that you are working with.
I assume that you are experiencing this issue recently and prior to that it was working as expected ?
Are you experiencing the same problem on other machines as well if you have similar setup ? (If any)
Please feel free to communicate on mayuresh.athalekar@autodesk.com to provide details directly if you feel so.
Mayuresh
”Boost
