Thank you in advance for any assistance, while updating the PLC database to include Siemens PLC's I ended up with this error twice. I dont know what is causing this.
I didn't have that same issue but when I tried to added MFG's it completed ok but they were still not added to the database and when I would re-run the installer to added the MFGs it would say that they were all ready installed so I do believe there are some issues with 2015
My work around was to install ACADE on a VM with all the MFGs selected then copy the PLC database file over to my main instalation of ACADE
Hi Erik,
Most of the time this error is received if the database is open or in Use (typically by AutoCAD Electrical).
In 2015 the database is also linked to Inventor.
So make sure you shutdown, AutoCAD Electrical, Inventor, and MS Access, before attemping the Database update.
You may also want to restart the computer to let any unfinished changes process. (so you start fresh).
I hope this helps,
James Alger
