AutoCAD Electrical Forum
ACADEL2008-DIN RAIL
2 REPLIES 2
272 Views, 2 Replies
ACADEL2008-DIN RAIL
WHEN TRYING TO PLACE IN A DWG DINRAIL. I GET AN ERROR ARGUMENT NOT FOUND wd_dinrl. SEARCHED FOR THIS FILE IT DOES NOT EXIST ON MY COMPUTER.
HELP
2 REPLIES 2
dougmcalexander
The wd_dinrl.xls file is located in the Catalogs folder by default. Have
you moved folders around for networking? the Catalogs folder is located by
default under My Documents\AeData\. The AeData folder can be moved to a
network drive, but you need to go to AutoCAD Electrical Options and add the
search path to the top of the Support File Search Path.
"alritter" wrote in message news:5595795@discussion.autodesk.com...
HELP
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
THANKS FOR THE HELP.
ALL I HAD TO DO WAS MOVE THE ALREADY EXISTING PATH TO THE TOP AND IT WORKS NOW.
