Hi all,
do any have a problem with Acade2014 Content Explorer?
Add circuit, add panel, add schematic component command missing on the right-click menu.
do you know how to add the menu back?
please refer to attached image.
thank you
I have never seen the Content Explorer.
How do you use it with ACADE?
Is there a benefit to using it?
Hi Bob,
Content Explorer is the quick way to insert the collection of block and Save circuit.
we save all the custom circuit and block in the our library using Write Block command.
then we map the content explorer to our library and insert circuit it by Right-click/add circuit.
to insert block by Right-click/add schematic component.
regards
Hi All,
same problem with AutocadE 2015,
anyone know how to add the command back?
thank you
Hi Mathalekar,
Have you find a solution for this?
this is still a problem for ACADE 2016 to 2017.
Thank you
