AutoCAD Electrical General Discussion
New Member
JonHoffman
Message 1 of 3 (79 Views)
Acade Line reference issue (%S%N = 11 rather than 101)
79 Views, 2 Replies
01-03-2007 11:01 AM
How do I get the line references to start at 101 rather than 11? The references go 11,12,13,14,15,16,17,18,19,110,111, etc. when I want them to go 101,102...
Active Contributor
Robert D. Janes
Message 2 of 3 (79 Views)
Re: Acade Line reference issue (%S%N = 11 rather than 101)
01-04-2007 06:16 AM in reply to: JonHoffman
Under the Project properties, Drawing Format tab, do you have Reference Numbers selected? If so go into set-up, what type of Line References are you doing? If you are doing Sheet Number and Numbers then your are probably on sheet 1. To make it clear change the format to Sheet-. No if it is just the sequence number you want to change, when you go to lay down a ladder change the 1st Reference.
Dean
New Member
JonHoffman
Message 3 of 3 (79 Views)
01-10-2007 10:08 AM in reply to: JonHoffman
This is Acade 2005, so I do not see the "drawing format" tab you mentioned. Basically the only problem is that Acade does not insert the zero between the sheet and line number for the first 9 lines on every page (11 instead of 101). It works correctly on another computer with the same project and version of Acade 2005, but I cannot figure out what the difference is in the settings between the two computers.
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
