AutoCAD Electrical Forum
ACADE 2014 terminals
2 REPLIES 2
DARRENASH5309
357 Views, 2 Replies
Looking at Electrical 2014 and when I insert a terminal, specifically one that should not change wire numbers, the numbers change on the other side of the terminal.
I have also checked to make sure the drawing template did not have any rogue terminals located in it.
Anyone else see this issue?
Darren
2 REPLIES 2
Be sure that your project isn't set for wire numbering on per wire basis.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
mathalekar
in reply to: DARRENASH5309
Hello Darren,
It depends on which terminal block you have selected to insert on the wire. If you have selected HT1001 (i.e terminal with wire number change) then it will give a new wire number after the terminal.
Secondly, if you have checked the checkbox in project setting for wire number as "on Per wire basis" then also it will change the wire number.
”Boost
