AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACADE 2014 RESETTING DEFAULT MENU/ICON MENU
1 REPLY 1
JAXXCAD
1052 Views, 1 Reply
During process of setting up IEC menu and Icon menu, lost info for default JIC settings.  How do I reset to default settings?
1 REPLY 1
dougmcalexander
in reply to: JAXXCAD
It sounds like you selected IEC as your default standard. That's okay. Just go onto control panel>programs and features and select AcadE 2014. Run the Add/Remove/Change function and select the JIC library as a secondary. I would suggest NFPA over JIC though. NFPA is more up to date.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
