It sounds like you selected IEC as your default standard. That's okay. Just go onto control panel>programs and features and select AcadE 2014. Run the Add/Remove/Change function and select the JIC library as a secondary. I would suggest NFPA over JIC though. NFPA is more up to date.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
