AutoCAD Electrical General Discussion
Active Member
0 Kudos
Post 1 of 3
ACADE 2012 Multiple balloon insert gone wrong
489 Views, 2 Replies
03-01-2012 08:30 AM
When inserting a balloon for a component that has multiple catalog references, the balloons are not inserted adjacent to each other. To get them aligned I must UnGroup the inserted balloons and then drag them into postion.
Is there a way to correct this insertion problem?
291 Kudos
Post 2 of 3
Re: ACADE 2012 Multiple balloon insert gone wrong
03-01-2012 02:53 PM in reply to: AScorgie
Be sure you haven't changed the balloon Direction options.  Version 2012 features the option to assign the direction of the additional balloons (i.e. up, down, left, right).  It will remember the last setting used.  Watch the command line prompt as you are inserting balloon leaders (see attached screen capture).  I haven't seen any negative issues wit this new feature, but you have to be aware that it will default to the last setting.  I always use angle with last segment.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
New Member
0 Kudos
Post 3 of 3
07-02-2012 06:24 AM in reply to: AScorgie
I am also having a problem with this.  Has there been any resolution found?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
