You could write a script, but you can do this in a simpler fashion. Just
copy the networked symbol to your local drive, perhaps your User folder, or
maybe create a folder called UserLib. Modify the WIRENO attributes to be
Invisible=Yes. Run Update Block but point it to the local version of the
block.
wrote in message news:5946284@discussion.autodesk.com...
That would work but we have a networked symbol library.
I can't change it.
I was thinking of a script to apply project wide.
Thanks anyways.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
