AutoCAD Electrical Forum
ACADE 2007 MULTIPLE BOM'S
7 REPLIES 7
Message 1 of 8
325 Views, 7 Replies
IN 2006 I DO TWO BOM'S ,ONE FOR HARDWARE AND ONE FOR PNEUMATIC. I USE TWO .SET FORMAT SETTING FILES.
BUT IN 2007 (USING THE SAME .SET FILES MOVED TO 2007)
THE HARDWARE BOM WORKS OK BUT WHEN I RUN THE PNEUMATICS BOM IT ONLY GETS A SMALL PART OF THE ITEMS. IF I RUN THE BOM ON JUST ONE DWG IT WORK FINE. WHY?
7 REPLIES 7
Message 2 of 8
Could you post the 2 .SET files. I would like to try this with the same
layout/setup as you have.
Steve
wrote in message news:5214244@discussion.autodesk.com...
Message 3 of 8
HOW TO I POST THEM
Message 4 of 8
It is different depending on which News reader you are using, but for
Outlook Express reader when you reply there is an option called 'File
Attachment' from the Insert pull-down menu.
If you are using the web interface, I am not sure of the exact option, but
there should be an option somewhere mentioning something about Attaching a
file. If you need details, let me know and I will get the exact steps.
Steve
wrote in message news:5214310@discussion.autodesk.com...
HOW TO I POST THEM
Message 5 of 8
here are the 1.set files i'm using
Message 6 of 8
here is the 2nd file
Message 7 of 8
Ok, I looked over the .SET files and they look Ok. I also used the .SET
files in some sample project here on both 2006 and 2007 and got the same
results in both packages on the same projects so maybe this has something to
do with the drawings themselves.
Do you have a small sample project that you could post that you are also
having this problem on?
Steve
wrote in message news:5214976@discussion.autodesk.com...
Message 8 of 8
do you have an email address so i can sent you a project.
can post it for all to see.
please email me with it al.ritter@marissystems.com
