When I use publish on the "Project Manager" palette, I have an issue only with certain projects when publishing to pdf. It always crashes.
It is always random which projects it "picks" to do this with....We set everything up the same way each time so I have no idea why it is picking random projects to "crash" I can publish to our copier just fine.
With random crashes you will struggle to pin down the issue but
check the file sizes anything above 1mB in size for a schmeatic page i would purge
run a script file through project wide utilities to zoom extents
open notepad and save the following with . scr extension
_CLAYER
0
_.ZOOM
_EXTENTS
_.QSAVE
this will give you a clue anything of the page off the page plot frame
also try a different pdf driver i use pdf redirect or primo pdf as alternatives to the autodesk pdf driver see whethter that makes a difference
otherwise you will have to keep going until you can consitantly replicate the crash
2 more days till retirement from ACADE
Are you running publishing to PDF in the background? Try unchecking the "publish in background" checkbox.
As you said that there is random crash, it's difficult to find the real reason.
From our support experience, could you try below solutions which has solved other customer successfully?
This is a common problem with the 2013 model which I myself struggled with for a while. If you are trying to publish in the background it will most likely crash.
Uncheck the "publish in background" box and this should fix it. Or you could update your system to the 2014 model which I believe they have fixed this bug.
