Thanks for the new EATON content.
But, after the installation, I don't find the mm version of the footprints !
I know I can produce the mm version with AEUPDATESYMLIB and the correct parameters.
Could you provide the mm version for the next packages ?
BR
Hi Doug,
I used this method until it has been possible to draw directly in mm (Ok for 25.4 when scale is 1, but 12.7 for 1/2, 6.35 for 1/4, it is not fun for end user).
It's easier when you can draw new footprint in mm.
You don't have to scale it in inches before you save it in the lib.
BR
I have to have footprints that work for both inches and mm since I do work for U.S. and European customers. So I always draw footprints in inches and scale for IEC. But if you only design in mm I can understand your wish.
Hello Bruno,
We have no separate directory for MM scaled panel footprints. However @dougmcalexander post is reliable way to handle the use of MM scale footprint. I shall see if i can do something quickly to have MM scaled footprints.
You should try AEUPDATESYMLIB command ( Schematic tabOther Tools panelSymbol Builder drop-down Modify Symbol Library ).
Make a copy of the library folder, than call AEUPDATESYMLIB command, select the new folder and use "Re-scale symbol" option.
I think that 24.5 is opposite to what you want to do.
Vladimir
